[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 384: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
• View topic - CaPRC 6/13 Match AAR
It is currently Sat Jun 15, 2024 4:19 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2  Next
 Post subject: CaPRC 6/13 Match AAR
PostPosted: Sun Jun 13, 2010 4:35 pm
We had 20 shooters show up to shoot today's match.
Total round count for the day was between 46 and 50 depending on how many shots were fired on KYL.
There were 790 points possible.
Here are a couple stages:
200yd coldbore
On the beep, engage the 2" dot at 200yds with 1 shot.
50 points for a hit, 0 for a miss.
50 points possible
60 seconds prep, 30 seconds shoot time.
100yd poker chips from behind the yellow line.
Start with ammo on the back benches & a round in hand, on the beep, move to rifle, engage a dot, open bolt, retrieve another round and engage another dot, repeat until finished.
20 points per broken poker chip.
60 seconds prep, 80 second shoot time.
60yd flies as done at sin city.
On the beep, engage any 5 flies on the paper.
10 points per fly.
50 points possible.
60 seconds prep, 45 seconds shoot time.
Holdovers, out and in.
On the beep, engage the plates in the following order: 150 little man, 300 small paddle #1, 500 circle, 300 small paddle #2, 150 little man. Shooter may not turn elevation knob during the string of fire.
15 points per hit.
90 points possible.
60 seconds prep, 60 seconds shoot time.
Natural Point of Aim
Shooter with get in the prone position and aim at his shooter number box on his 100yd KYL target. Shooter will signify when ready and a blind fold will be placed over the scope. After 3 seconds, the beep will sound and the shooter has 5 seconds to engage the target.
25 points for a hit
25 points possible
30 sec prep and 5 sec shoot.
200 yard hostage.
On the beep, engage the hostage target at 200 yards from the prone position with two rounds on each side.
20 points for bad guy and -20 points for hostage hit.
80 points possible
30 sec prep and 30 sec shoot.
Standard KYL with octagons.
Round count: up to 5
On the beep, engage the octagons from largest to smallest, stopping if you do not believe you can make a sure hit. A miss causes shooter to zero the whole target.
Points are 10, 15, 20, 25 & 30.
Quick transistions.
Round count: 6, fired in 3 strings of 2.
On the beep, engage the two small paddles at 300yds with 1 shot each.
15 points per hit.
90 points possible.
60 seconds prep, 6 second shoot time per string.
Pool balls.
Round count: up to 9
On the beep, engage all the solid pool balls. The 8 ball is optional. A hit to the 8 ball without also hitting all other solid balls causes the shooter to lose all points.
10 points per ball except the 8 ball is worth 30 or zero points if all solids are not hit.
Unsupported positions.
On the beep, engage the 100yd mini IPSC target center of mass with 2 shots offhand, 2 shots kneeling, 2 shots seated and finally 2 head shots from prone.
Scoring as per the point values on the target.
80 points possible.
Stage 11
Shooting aces.
On the beep, engage the square in the center of the playing card target with 1 shot.
25 points for a hit touching the white center, 15 points for a hit touching the black line, but not touching the white center.
25 points possible.
60 seconds prep, 10 seconds shoot time.
 Post subject: Re: CaPRC 6/13 Match AAR
PostPosted: Sun Jun 13, 2010 4:42 pm
I do think I want to see mine :cry: Oh well, every match is a chance for improvement
PostPosted: Sun Jun 13, 2010 5:02 pm
Thanks guys for putting this together. It was a blast!!
had a great time and learned a few things!
sonny
PostPosted: Sun Jun 13, 2010 5:10 pm
Thank you Brad and Randall. Awesome time as usual and very well run today.
We should take a moment to recognize the flakes that sent their RSVP but pussied out because they are PWed
Cough... cough.....brian01tj
PostPosted: Sun Jun 13, 2010 5:21 pm
Nice!!! Congrats on placing 1st, James!
I'll be joining you guys in the next month's match.....finally!! :)
Kevin H.
PostPosted: Sun Jun 13, 2010 5:22 pm
Are the stages the same for every month's Angeles match?
Kevin H.
PostPosted: Sun Jun 13, 2010 5:35 pm
PostPosted: Sun Jun 13, 2010 5:41 pm
PostPosted: Sun Jun 13, 2010 6:13 pm
Someone left their rear bag on the range, I took it home with me. Send me a pm and I will bring it with to the next match so you can claim it. It is ACU colored cylindrical shaped bag (triad I think).
PostPosted: Sun Jun 13, 2010 6:14 pm
Great day today... Nice to see some new shooters on the line...
Now I need to lean to make a CB shot.
PostPosted: Sun Jun 13, 2010 6:43 pm
Cool COF. Pretty much covers the essence of all the popular stages.
Good shooting James Michael and Charles. Your scores weren't even close to each other (means you really whooped the next person's ass).
PostPosted: Sun Jun 13, 2010 6:56 pm
PostPosted: Sun Jun 13, 2010 7:03 pm
Great shooting guys!
Hope to make it out there next month.
PostPosted: Sun Jun 13, 2010 7:12 pm
I moved on to forgetting to dial DOPE.
PostPosted: Sun Jun 13, 2010 7:31 pm
Great turnout!
Good shooting James.
PostPosted: Sun Jun 13, 2010 7:32 pm
We all did better than Ryan...
PostPosted: Sun Jun 13, 2010 7:36 pm
BIG THANKS to Randall, Brad and everyone who made for a great match! I had a blast and am really looking forward to the next shoot. Not sure if I will bring out my .260, I like me TOP 308 title! haha~!
Here are some random pics from the match...
Upgrade your AICS: http://www.victorcompanyusa.com
PostPosted: Sun Jun 13, 2010 7:37 pm
PostPosted: Sun Jun 13, 2010 7:39 pm
PostPosted: Sun Jun 13, 2010 7:40 pm
PostPosted: Sun Jun 13, 2010 7:43 pm
PostPosted: Sun Jun 13, 2010 7:45 pm
PostPosted: Sun Jun 13, 2010 7:53 pm
PostPosted: Sun Jun 13, 2010 7:57 pm
This is a cool pic
PostPosted: Sun Jun 13, 2010 8:06 pm
Pissed at myself for not sending another round into the pool ball that I missed. That cost me 100 points since I hit the 8ball. Learning lesson.
PostPosted: Sun Jun 13, 2010 8:08 pm
PostPosted: Sun Jun 13, 2010 8:10 pm
PostPosted: Sun Jun 13, 2010 8:13 pm
PostPosted: Sun Jun 13, 2010 8:14 pm
PostPosted: Sun Jun 13, 2010 8:16 pm
goodtimes
PostPosted: Sun Jun 13, 2010 8:57 pm
Thanks guys, had as much fun as one can have being at the range for 6 hours and not shooting.
There are no stupid questions, just stupid people asking questions
PostPosted: Sun Jun 13, 2010 9:00 pm
PostPosted: Sun Jun 13, 2010 10:06 pm
Zach
PostPosted: Sun Jun 13, 2010 10:14 pm
What's with the shooting mats and shade? You guys going country club on us? :)
Rob Thomas - Match Director - NCPPRC Long Range Match
PostPosted: Sun Jun 13, 2010 10:28 pm
PostPosted: Mon Jun 14, 2010 5:07 am
Thanks for posting the video.
PostPosted: Mon Jun 14, 2010 5:57 am
I like the shirts.
PostPosted: Mon Jun 14, 2010 6:02 am
Hay Randall
According to the date on the video, the match is in two days.
I know the club is good, but I don't think we can alter time, yet.
PostPosted: Mon Jun 14, 2010 6:55 am
PostPosted: Mon Jun 14, 2010 12:28 pm
Thanks very much for a great time yesterday guys. Very newbie friendly and a ton of fun. I got lots of great advice from plenty of patient people willing to take the time to give me tips on some fundamentals I can improve on. After the first stage jitters passed I just settled into having a good time and making the most of experiencing shooting a bolt rifle on the clock at a lot of new target types (in some interesting shooting positions too haha).
Looking forward to the next one. Thanks again for a great day of shooting!
PostPosted: Mon Jun 14, 2010 2:26 pm
This was a very enjoyable and well run match. Next time I'll pay more attention and try to shoot on my own target.
BTW Randall, I did RSVP and I did come.....Crow King
PostPosted: Mon Jun 14, 2010 2:30 pm
PostPosted: Mon Jun 14, 2010 3:24 pm
I had a great time. It was the first match I had shot in two years and can't wait until the next.
PostPosted: Mon Jun 14, 2010 3:25 pm
AAR = ASR
Zach
PostPosted: Mon Jun 14, 2010 3:36 pm
After
Action
Report
PostPosted: Mon Jun 14, 2010 3:43 pm
Acronym fail..
PostPosted: Mon Jun 14, 2010 4:50 pm
Zach
Users browsing this forum: No registered users and 46 guests
cron
