We had 17 shooters show up to shoot today's match out of 21 RSVP's. Ryan and James were gracious enough to run the match. Thanks a bunch guys!
Total round count for the day was between 41 and 42 depending on how many shots were fired on the cold bore target. There were 570 points possible.
Stage 1 400yd coldbore Round count: 2 On the beep, engage the 6" dot at 400yds with 1 or 2 shots. 50 points for a first round hit, 20 points for first round miss and a 2nd round hit or 0 points for two misses. 50 points possible 60 seconds prep, 30 seconds shoot time.
Stage 2 200 yard hostage. Round count: 4 On the beep, engage the hostage target at 200 yards from the prone position with two rounds on each side. 20 points for bad guy and -20 points for hostage hit. 80 points possible 30 sec prep and 30 sec shoot.
Stage 3 25yd 5 dot drill on 1/2" dots. Round count: 5 On the beep, engage the 3/8" dots at 20yds with 1 shot each. 10 points per dot. 50 points possible. 60 seconds prep, 45 seconds shoot time. Use a 2x4 laying on edge with cardboard or heavy card stock stapled to the edge of 2x4 to keep the target very close to the ground.
Stage 4 Holdovers, in and out. Round count: 7 On the beep, engage the plates in the following order: 400 circle, 300 small paddle, 200 little man, 150 circle, 200 little man, 300 small paddle, 400 circle. Shooter may not turn elevation knob during the string of fire. 15 points per hit. 105 points possible. 60 seconds prep, 60 seconds shoot time.
Stage 5 100yd poker chips from behind the yellow line. Round count: 5 Start with ammo on the back benches & a round in hand, on the beep, move to rifle, engage a dot, open bolt, retrieve another round and engage another dot, repeat until finished. 20 points per broken poker chip. 100 points possible. 60 seconds prep, 80 second shoot time.
Stage 6 Unsupported positions. Round count: 8 On the beep, engage the 100yd mini IPSC target center of mass with 2 shots offhand, 2 shots kneeling, 2 shots seated and finally 2 shots from unsupported prone. Scoring as per the point values on the target. 80 points possible. 60 seconds prep, 60 seconds shoot time.
Stage 7 100 yard spelling bee Round count: 5 On the beep, spell out an assigned 5 letter word by shooting the letters on the target form the prone position. 30 points for spelling the word or 0 points if a letter is missed. 30 seconds prep, 60 seconds shoot time.
Stage 8 was thrown out due to target failures before all shooters could complete it.
Stage 9 300 yard IPSC. Round count: 5 on the beep engage the small ipsc target with 5 rounds from the prone position. 10 points for hitting the black conter and 5 for other hits. 50 points possible. 30 sec prep and 30 sec shoot time. 50 possible points.
Stage 10 Shooting aces. Round count: 1 On the beep, engage the square in the center of the playing card target with 1 shot. 25 points for a hit touching the white center, 15 points for a hit touching the black line, but not touching the white center. 25 points possible. 60 seconds prep, 10 seconds shoot time.
482 Randall R 447 Brad B 365 Kurtis K 315 Sonny 301 Joe H 299 Ken 285 Brian 265 Joe V 258 Keith 240 Michael V 233 Robert 125 Mike Y 110 Colin 104 Andrew 86 Craig 77 Steven 5 Shaun
_________________ God shoots a Remington 700, drives a Chevy Truck and carries a Glock 19. I don't do any of those things.
