[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
• View topic - ASR Actual Steel Distances
It is currently Wed May 22, 2024 5:52 am
Post new topic Reply to topic  [ 9 posts ]
PostPosted: Mon Jun 22, 2015 3:14 pm
Bore Brusher
Hey all, does anyone have the exact distances for the steel targets at Angeles? The RO's confirmed what my dope is telling me, that they're a bit off from the set 100 yard increments, was hoping to get some better numbers. Thanks.
Guy Fieri wears Gatorz
PostPosted: Mon Jun 22, 2015 3:23 pm
Exact numbers? I'm sure it would depend on exactly where you are on the firing line
"Democracy is two wolves and a lamb deciding what to have for dinner.
Liberty is a well armed lamb with a SAC Alpha 11 protesting that decision." Unknown 2017
PostPosted: Mon Jun 22, 2015 9:06 pm
Bore Brusher
Perpendicular to the firing line then, at least a better idea than the nominal distances they give. I'm trying to back-track MV for a couple loads without having to chrono them.
I figure at least one person knows their MV and dope on each of the targets with a given set of environmental conditions and has figured out what the actual distances are.
PostPosted: Mon Jun 22, 2015 10:15 pm
The smallest square flapper at 500Y is pretty bang on from the left side of the line. It's right at 1-1.25MOA so it's your best bet for confirming DOPE.
PostPosted: Tue Jun 23, 2015 1:40 pm
PostPosted: Wed Jun 24, 2015 3:12 pm
Bore Brusher
Gotcha, I didn't really think about it much but I guess the angles are significant if you're sweeping across the line. I did come across a thread on calguns discussing DA where a few had mentioned they had independently ranged them and they were within +/- 5 yards of the nominal distances, so if someone comes along looking for this answer later, there you have it. Time for some trigonometry, and I guess allocating the funds for a RF.
Also it was an SPR whose brake you helped me time a while back Randall, so thanks again for that.
PostPosted: Thu Jun 25, 2015 5:11 pm
Well the distances are going to vary slightly depending on where you are on the line. If you laze from the ground (with a steady spot to set the rangefinder on) the corrected value may differ than if you laze from the bench.
I was there today and from about middle of the line to the small hanger on the 600 line I lazed it as 608 with corrections for angle to 590. Nailed it on the first shot and confirmed hard dope at all distances up and down the line using these corrected values.
Rifle was dialed in and center punched 1/2 inch dots at 100. Why can't I do that when it counts?!
PostPosted: Thu Jun 25, 2015 6:48 pm
PostPosted: Fri Jun 26, 2015 4:14 pm
Bore Brusher
Users browsing this forum: No registered users and 4 guests
