5/25/14 CAPRC Match
Mobius38
Teaches Shooting
Real Name: Esteban Masanis
Re: 5/25/14 CAPRC Match
Post by Mobius38 »
Thanks for another great match! Walk away always learning more and more each time. I can say this at least I am consistently right in the middle.
Point of Impact
Real Name: Ben
Post by Point of Impact »
Had a great time "getting back in the saddle" today guys. Thanks to everyone who made it happen. Placed where I usually place.....in the middle of the pack. (thanks to Solomon pointing out a .2 mil left correction needed in my zero,) :thumb:
5/25/14 CAPRC Match
We had 20 shooters out of 21 RSVP's.
The course of fire:
Stage 1 - 400yd Cold Bore option
Round Count 1
Start position: Prone, mag in, bolt open.
On the start signal, shooter will drop to prone position and engage the either the large or small steel target with one shot.
Shooter must call out shot before shooting.
Target “A” 20 points for a hit
Target “B” 40 points for a hit
20 seconds shoot time
Stage 2 - Little hostages at 100
Round count 5
Start position: Standing port arms, mag in, bolt open.
On the start signal shooter will drop to prone position and engage little hostage targets making sure to only shoot the black hostage takers. Hostages shot will result in loss of points.
15 points per hostage taker hit
-15 points per hostage hit
45 seconds shoot time
Stage 3 - Kneeling and Seated
Round count 8
Start position: Kneeling position, mag in, bolt open
On the start signal shooter will engage 100yd IPSC paper target from the kneeling position with four rounds, then transition to a seated position for four more rounds.
Only sling, glove, or shemagh may be used for support. Bag under ankle ok.
Targets will be scored for point value on target.
99 seconds shoot time
Stage 4B- TYL Rack 300yd
Round count 8
Start position: Prone behind rifle, mag in, bolt open
On the start signal shooter will shoot 300yd swinging dots from largest to smallest in order. If shooter clears rack, shooter may continue to start rack again for more points. However shots missed or out of order means shooter must start at first plate again, and will lose all accumulated points up to that point. Shooter may stop at any time.
Plates are worth 5,10,15,20,25
60 second shoot time
Stage 5A - Stand and Deliver
Round count 6
On the start signal shooter will engage steel target at 200yd from the standing offhand position with no artificial support of any kind. Once shooter hits target once, then target “A” at 600yd may be engaged with remaining rounds from the prone position.
Stage 6A - Defilade
Round count 5
On the start signal shooter will engage hidden steel target at 550 with 5 rounds using only”D” indicator sign as a reference point from the prone position. Shooters will be allowed one minute to view reference from bench position before shooting.
Stage 7B - Confirmed Swinger
Round count 6
On the start signal shooter will engage medium men rack at 300yd from left to right while confirming each hit afterward with a shot at the 600yd “B” target. Targets must be hit to move to next target.
15 points for each correct hit
70 second shoot time
Stage 8B - Holdovers
Round count 6
Start position: standing port arms
On the start signal shooter will drop to prone position and engage targets in the following order without touching their elevation turrets: 400 “B”, 200, 500, 300 Middle Medium Man, 600 “B”, 400”B”. Shooter may not move on until target is hit.
90 seconds shoot time
Stage 9A - Barricade Assault
Round count 10
On the start signal shooter will engage 300 yd popper from barricade with two shots through each port hole. Shooters may not repeat any positions, and bolt must be open on all transitions.
120 seconds shoot time
Stage 10A - Tactical Bench Rest
Round count 6
Start position behind rifle on shooting bench, mag in, bolt open
On the start signal shooter will engage 400 yd target “A” using only a pack or bag as support with two rounds. Shooter will then transition to opposite side bench to shoot support side with bipod allowed with two round at 400 yd target “A”. Shooter may then transition to prone support side for remaining two shots at 600 yd “A” target.
70 seconds shoot time
Results were as follows:
675 Ray Riganian
500 Rich Chronister
490 Aaron Gifford
475 Soloman manasala
470 Sam chu
435 Henry Garay top 308
410 Oscar milanes
435 Nathan Webnar
335 Brad Bolves
310 Kirk dean
295 Ben arias
290 John Packard
290 Esteban masanis
290 Jennifer toms
265 Danny Nguyen
245 Steven Rogers
195 Jeff hall
155 Jeff holder
120 Chris holzhauser
DNF John Lee
Scoresheet:
Point of Impact
Real Name: Ben
^^Hey Randall, I just noticed I got marked for 30 points on stage 10. I got 4 hits on that stage...was keeping score on my COF. No biggie, just good for me mentally when I stay in top 10. thanks again.
Downrange67
Real Name: Henry Garay
Post by Downrange67 »
A sling was left behind, check your stuff.
Tomorrow's Battle Is Won During Today's Practice!
robojet
Real Name: Jennifer
Post by robojet »
I think we need a report on Nathan's thumb... Pictures to...
robojet
Real Name: Jennifer
Post by robojet »
Do u keep these scores for any reason beyond the match? Because #13 should have had 15 points on stage 7 making the total 300 and bumping me up 2 places :). It was a typo... 5 points wasn't possible on that stage as it was increments of 15
snappy
Real Name: Brad Bolves
Post by snappy »
Short Action Precision wrote:Bringing a sweet prize for some lucky winner this month! No its not a cooler!
What was it, and I thought it went to the winner of stage 6A?
There are no stupid questions, just stupid people asking questions
Real Name: Nathan Webnar
Post by Short Action Precision »
Nice Seekins hat. Rays head was to big and Rich and I gave it away so it went to 3rd place Aaron G.
evo
Real Name: Evin Grant
Post by evo »
Looks like you're getting you're groove back Ray! Good shooting Rich and Arron, sorry I missed it, seemed like a good turn out.
Treadstone
Real Name: Jeff
Post by Treadstone »
A very challenging and fun match! I and several others really enjoyed the hidden target stage. Would like to see more of these!
I'd also love to see some unknown distance targets (size is known) to give us practice ranging using our reticle and doing the calculations under time pressure!
Barricades and sling work is a real weakness for me, so please keep including those kinds of stages!
Congrats to the winners!
postal
Real Name: Julian
Post by postal »
#2-#5 is really close.....
Good job all.
Treadstone wrote: I'd also love to see some unknown distance targets (size is known) to give us practice ranging using our reticle and doing the calculations under time pressure!
I think these are hard to do at ASR. The berms give a pretty close guesstamite of distances.
Nosmas
Real Name: Samson C
Post by Nosmas »
Can anything be placed beyond 600?
Sam
Nosmas wrote:Can anything be placed beyond 600?
Not if they know about it
shawscar17
Real Name: Oscar Milanes
Post by shawscar17 »
Had a blast yesterday! Thanks to those that helped set up, organized, and run the match. Your hard work is really appreciated. To any veterans or active duty service member, thank you for you service. I will never forget those that made the ultimate sacrifice. Freedom is not free.
MajorHeadTrauma
Real Name: Kirk Dean
Post by MajorHeadTrauma »
deepsix++ wrote:i got the case un stuck
Body sizing in the chamber!
Treadstone
Real Name: Jeff
But perfect for a match out in the desert! We could do a club match away from ASR now and then?
peerless
Real Name: RAY RIGANIAN
Post by peerless »
the stage #6 was an unusual one,sure got me puzzled,when i got behind my rifle
to shoot I did not know what I was doing , the only shooter did good was Brad,
when he explained it to some of us on a paper ,it sure clicked what was happening,
I think next time I can do better on stages like that,
thanks Brad and Randall for their innovative course of fires.
http://www.peerlessrifleco.com
"One of the secrets to mastery in any field is to forever be a student."
Capnjon
Real Name: Jonathan Packard
Post by Capnjon »
It had me puzzled too! I can grasp it today having thought about it but I guess my dyslexia kicked in under pressure.
snappy
Post by snappy »
I had nothing to do with the COF, it was all Rich and Randall this time.
I just helped to set up the night before.
It was a nice change for me to just shoot, even though I shot like &%$@#.
I am glad to see new faces on the line, and hope people are learning.
deepsix++
Real Name: Sam Hoskins
Post by deepsix++ »
I know the perfect place
peerless wrote:the stage #6 was an unusual one,sure got me puzzled,when i got behind my rifle
I told Brad how I would run that stage if I were shooting.
Looks like my idea worked...
thegiff
Real Name: JackBlack
Post by thegiff »
I got 3 on stage #6, I found a rock that was straight up and used that as my reference. Cool though, cuz the bullets were flying over the cardboard then coming back down to hit the plate that you couldn't see directly since it was behind the cardboard. My first 2 shots missed, so I guessed I was shooting right (I saw a left to right mirage come up) so I edged a little left and started getting hits.
Ray sure shot impressively, he ran away with the points score.
:ban:
Downrange67 wrote:A sling was left behind, check your stuff.
Yeah that would be a big NO... They have had 2 fires out beyond 600 from people shooting rocks... yes, it was probably steel jacket/core ammo, but let's not chance it as I have shot rocks and steel with regular copper jacketed bullets and I saw sparks...
Man... I shot like shit yesterday and the hostage targets cost me 30 points and I don't know wtf I was doing on the Defliade stage...Of course after I took Brads advice on adjusting the turrets I was able to hit it...
Still had fun... And who ever pounded those stakes in really sunk them in....
peerless
Post by peerless »
Good thinking Randull,
Thanks Rich.
