Myself, Connor & Charlie ran the match.
EmphaticThumb, EmphaticThumb's wife, EmphaticThumb's brother, Southpaw58 & higginsworksforme helped run the line.
Total round count for the day was 50.
There were 10 stages with 1000 total points possible.
200yd Coldbore
On the start signal, engage the left square of the 200yd hostage target with one shot.
55 points for a hit completely inside the scoring square (not touching the line), -20 for any hostage hit
55 points possible
30 second prep time 20 second shoot time
http://www.caprc.com/targets/double-hostage.pdf" onclick="window.open(this.href);return false;
Barricade
On the start signal, engage the 350yd 10" green plate with 2 shots from each of the following positions: standing, kneeling, seated & prone, using only the barricade for support.
120 points possible
100 second shoot time
Timed exposures
On the start signal, engage the 400yd spring loaded red ipsc plate with 2 shots. Each time the target becomes visible again, engage with 2 more shots.
15 points her hit
90 points possible
1st string shoot time is 16 seconds, then 2 more random 6 second intervals
Positional KYL
On the start signal, engage the 250yd 8" yellow/blue circle with 1 shot from each of the following positions: prone, seated, kneeling then standing. You may stop at any time. A miss causes the target to be zeroed.
hit point values as follows: 10, 30, 40, 50
130 points possible
120 seconds shoot time
Little hostages
On the start signal, engage the 5 hostage takers at 25yds with 1 shot each.
Rounds striking 2 scoring areas will be scored as only one hit.
Rounds striking a hostage and a hostage taker will be scored as hostage hits.
20 points per hostage taker hit or -20 per hostage hit
40 seconds shoot time
http://www.caprc.com/targets/25hostages.pdf" onclick="window.open(this.href);return false;
Speed drill
On the start signal, engage the target with as many shots as you can. A shot after the par time will cause one hit to be removed during scoring. This stage starts with shooter on target, bolt closed.
20 points per scoring hit
10 seconds shoot time
http://www.caprc.com/targets/2.5inchdots.pdf" onclick="window.open(this.href);return false;
200yd hostages
On the start signal, engage the right square of the 200yd hostage target with 5 shots.
20 points per scoring square hit, 10 points for any other hostage taker hit, -20 for any hostage hit
300yd KYL
On the start signal, engage the green swinging dots from largest to smallest with 1 shot each. You may stop at any time if you are not sure you can make the shot. A miss causes all stage points to be lost.
Round count: up to 6
Plates values as follows, largest to smallest: 5, 10, 15, 20, 25, 30
105 points possible
60 seconds shoot time
Time ticking down
On the start signal, engage the 6" red circle at 300yds with 1 shot. This stage is fired as 5 separate passes, with descending par times per pass as follows: 17, 14, 11, 8 and finally 5 seconds. Shots after the par time will cause one hit to be removed during scoring.
20 points per hit
40 second shoot time
Man on men
On the start signal, engage the 200yd yellow little men with 1 shot each from outside to inside and then the 300yd stop plate. You must hit each plate before you proceed to the next. Only the first shooter to hit the stop plate will earn points for their stop plate.
20 points per hit
585 John L (top 308)
570 Brad B
565 Michael V
545 Keith N
495 Jeff B
490 Joe V
455 Mike S
450 Steven R
440 Ray R
370 Nick P
315 Henry S
265 Eddie J
255 Sonny M
205 Nathan W
150 Colin C
40 Richard C
 nobody cleaned it today.
