6 were 1st time caprc match shooters.
Brad, Connor & Keith ran the match.
maddesign, Southpaw58, Emilio, DavidRSA & NotoriousPDL helped run the line.
Total round count for the day was 50.
There were 10 stages with 1000 total points possible.
300yd Coldbore
Start position: Standing at yellow line, port arms, bolt open.
On the start signal, engage your 3” shoot-n-see circle at 300yds with one shot.
60 points for a hit
60 points possible
60 second shoot time
400yd Barricade
On the start signal, engage the 10" green/yellow plate with three shots from each level of the barricade.
Round count: 9
135 points possible
90 second shoot time
300yd Timed exposures
Start position: Prone, rifle on target, bolt closed.
On the start signal, engage the left little man with 1 shot then engage the right little man with 1 shot. There will be 3 separate start signals at random time intervals once the stage begins.
20 points for a hit
120 points possible
5 second shoot time per string, 3 strings in 70 seconds
200yd little man speed drill
Start position: Standing at start line, rifle on target, bolt open.
On the start signal, engage the little men from left to right with one shot each.
15 points for a hit
120 points possible
500yd Benchtop
On the start signal, engage the 8" green plate with 4 shots. No rear support may be used, bare hand only.
20 points for a hit
80 points possible
40 second shoot time
400yd weakside
Start position: Standing at yellow line, rifle on target, bolt open.
On the start signal, engage the 6" flappers in the following order: left right left right.
20 points for a hit
80 points possible
300yd seated
Start position: Seated, rifle on target, bolt open.
On the start signal, engage the 8" plate with 5 shots.
25 points for a hit
125 points possible
longrange transistions
Start position: Standing at yellow line, 1 round in hand, rifle on target, bolt open.
On the start signal, engage the green plates in the following order: 600-500-600-400-600. Shooter must retrieve one round at a time from the back bench.
20 points per hit
200yd unsupported suits
Start position: Unsupported prone, rifle on target, bolt open.
On each start signal, engage the specified suit with one shot. Repeat until all 4 suits have been engaged.
25 points per hit
80 second shoot time
200yd man on man
Start position: Standing at yellow line, rifle on pack, bolt open.
On the start signal, engage the little men from left to right with one shot each. Winner decided by number of hits then ties broken by time. No bipod support allowed.
20 points per hit
80 points possible
510 Randall R
460 Nathan W
460 Ray R
440 Mike S
435 Brian L
400 Rich G
380 Michael V
340 Eddie J
305 Brandon M
295 John L
275 Evan G
270 Ho C
200 Steven R
190 Tyler F
185 Tyler S
135 Mike L
135 Shavarsh A
75 Charles H
50 James Q
