Modern Mad Minute
				6079Winston
- Real Name: Jeff Butler
Modern Mad Minute
I want to try this, but only when I have a switch barrel rifle and a beater barrel.
http://bulletin.accurateshooter.com/201 ... ngskyting/" onclick="window.open(this.href);return false;
				Mad minute
- Real Name: John England
Re: Modern Mad Minute
go buy a cheap enfield!
						- GforceJunkie
- Real Name: Mike S.
How many mags do you have for your .22 upper caus I just got a great idea
 6079Winston wrote:I want to try this, but only when I have a switch barrel rifle and a beater barrel.
				6079Winston
I have about a dozen mags, just none that actually feed all the time. I'm going to take the hint and try to get a handful ready for the next rimfire matchGforceJunkie wrote:How many mags do you have for your .22 upper caus I just got a great idea
				bcrich
- Teaches Shooting
- Real Name: Rich Gonzalez
Wow, those dudes are amazingly fast. Joe H and Joe V could give them a run for there money! Right Joe's
				johnlee
- Real Name: John Lee
I hope you have a Mad Minute stage in the next rimfire match. Who cares if the autos have an advantage or not. That stage looks like fun.GforceJunkie wrote:I just got a great idea
- Stoopy
- Real Name: Reese Stoops
- Location: In the middle of the desert somewhere outside of Barstow
Modern Mad Minute
Just make the target smaller or farther away and that should help level the playing field for the bolt actions.johnlee wrote:
Noxx wrote: You're cuckoo for Cuoco muff?
				johnlee
Good idea.
Also, perhaps shooting a Mad Minute stage from something like sitting or slung prone rather than bipod prone might make equipment less of a factor.
Whatever you end up doing, I hope to see a Mad Minute in a forthcoming rimfire match. That really looks like fun.
- Stoopy
Modern Mad Minute
Yes but hopefully prone because I suck at positional stages.
- GforceJunkie
Prepare to have fun thenjohnlee wrote: Whatever you end up doing, I hope to see a Mad Minute in a forthcoming rimfire match. That really looks like fun.
  I decided to seperate the semi's and the bolt guns to make things fair.
  I decided to seperate the semi's and the bolt guns to make things fair.-
				johnlee
I was surfing GunsAmerica during lunch and ran across this mad minute special:
http://www.gunsamerica.com/922194270/Gu ... r_22LR.htm#" onclick="window.open(this.href);return false;
Fuck it. I bought it.
Unfortunately, I won't have possession of it in time for this weekend's rimfire match.
				Short Action Precision
- Real Name: Nathan Webnar
You my friend have a disease!!!
						- Stoopy
Modern Mad Minute
Very nice gun John. So will there be a mad minute challenge this Sunday?johnlee wrote:I was surfing GunsAmerica during lunch and ran across this mad minute special:
				johnlee
I don't know for sure, but I'm guessing there will be based on what Mike wrote previously:Stoopy wrote:So will there be a mad minute challenge this Sunday?
GforceJunkie wrote:Prepare to have fun then
- Stoopy
Modern Mad Minute
Does anyone know of a good shot timer app for iPhones?
- Stoopy
Modern Mad Minute
Nevermind I found one I had on my phone already.  Sure fire if anyone else wants to know.
Modern Mad Minute
It sucks. Especially if you are shooting under cover. can't seem to get the echo and microphone  calibrated right
						- Stoopy
Modern Mad Minute
I was using it for dry fire practice. Just a timer with buzzers and a delayed start. It worked ok for that but i was keeping track of how many trigger pulls I made so i knew when to change mags. Mag changes is where the mad minute is won or lost, at least that's what I think.Gnzrme wrote:It sucks. Especially if you are shooting under cover. can't seem to get the echo and microphone calibrated right
- evo
- Real Name: Evin Grant
I can blow through a 10 round mag in the MKII pretty quickly but I keep accidentally engaging the saftey.  Anyone here have any ideas about disengaging or removing the lever? I don't think it's strictly necessary on a .22 bolt with the Accutrigger.
						- Stoopy
Modern Mad Minute
don't you have to have a functioning safety according to the match rules? I know they never check so maybe I'm wrong.evo wrote:I can blow through a 10 round mag in the MKII pretty quickly but I keep accidentally engaging the saftey. Anyone here have any ideas about disengaging or removing the lever? I don't think it's strictly necessary on a .22 bolt with the Accutrigger.
- Stoopy
Modern Mad Minute
Just found it rule 3
Mark your calenders and get your .22's tuned up! CaPRC is proud to announce the 2012 tactical Precision Rimfire match schedule an Angeles Shooting Range:
Feb. 26th (on main rifle line)
April 15th (on main rifle line)
June 24th (on Fort Angeles private range)
Aug. 26th (on Fort Angeles private range)
Nov. 11th (on main rifle line)
CaPRC Tactical Precision Rimfire General Rules, Guides, & Suggestions
The Hardware
1) Rifle: Any bolt action or semi auto, .22lr caliber.
2) Optics: unlimited.
3) A functional safety required on all rifles.
4) All rifles must be able to eject a live round
5) .22lr caliber only. No magnum or .17. No Hypervelocity ammo.
6) Chamber flag required. Not required to be inserted into chamber, Passed through ejection port and down through mag well is acceptable.
Highly recommended
1) Bipod, sling, and rear bag for support.
2) 10 round magazines, enough magazines for 20 round stages.
3) Target grade match ammo.
4) Scope of at least 10x power with milling reticle.
5) At least 27 moa of scope adjustment from 50 yd zero. May require 20 moa scope base.
6) Dope from 10 to 200 yards.
Nice to have
1) Shooting mat or other ground cover.
2) Binoculars or spotting scope
3) Elbow and knee pads
4) Drinks and snacks.
The Action
1) Be prepared to shoot from the prone, sitting, kneeling and standing positions with and without support.
2) Be prepared to shoot over, under, around and through barricades or obstacles.
3) Be prepared to engage targets from 10 to 200 yards.
4) Be prepared to shoot strong and weak side.
5) Be prepared to have fun!
Helpfull data and links
1) Randall's dope chart for Wolf Match. First number is MOA, second number below it is wind hold for 10 mph in MIL's.
http://www.ar15barrels.com/data/22dope.pdf
2) Wolf Match data for your ballistic program:
BC = .130 G1
FPS= 1050 typical with 20" barrel
3) Review of Tactical Precision match by 6mmbr.com: http://www.6mmbr.com/rimfiretactical.html
The Hardware
Highly recommended
Nice to have
The Action
BC = .130 G1
- evo
Ahh, OK missed that.  Maybe I can come up with a block or something just for the rapid fire stage.
						- GforceJunkie
You have to have a functioning safety for our matches.  Perhaps remove the big knob on the savage lever and just have enough of the sheet metal lever sticking up so it can be functional.
						- Stoopy
Modern Mad Minute
that's a good idea, HSLD safety lever.GforceJunkie wrote:You have to have a functioning safety for our matches. Perhaps remove the big knob on the savage trigger and just have enough of the sheet metal lever sticking up so it can be functional.
- evo
I'll see what I can whip up, I was hoping not to permanently modify, but I might be able to remove the knob but then tap and bolt it back on after the match.
