Aug 17 PBR AAR WEGC
				bcrich
- Teaches Shooting
- Real Name: Rich Gonzalez
Aug 17 PBR AAR WEGC
Today's match had a great turnout with 16 shooters & 3 new faces to PBR Howard,Jennifer & Jeff thanks for coming out & participating... Hope you all become regulars at future matches.
The weather was nice but the wind did start to blow making those longer shots a challenge.
We had 9 stages & completed the match by 1:15
Congrats to the top finishers you guys shot great today & Henry took 2 medals with his 308 awesome job Henry!
1st place Soloman 413
2nd place Jason 350
3rd place Rich C 347
4. Aaron 344
5. Esteban 243
6. Henry G 205 takes top 308 award & also top long shot
7. Larry 198
8. Ben 194
9. Jeff Holder 169
10. Jennifer 154
11. Jeff Hall 149
12. Netza 120
13. Eddy 97
14. Julian 89
15. Danny 186. DNF
16. Howard DNF
Cof was as follows
LONG RANGE TOP PAD
Stage 1 - Cold Bore chaos (2 shooters at a time)
Targets *YELLOW* - (2) IPSC flappers @ 393yds, (2) 8" hanging @ 514yds, (2) Skinny sammies @ 294yds
75 seconds
(6) rounds
Starting standing with rifle on ground, mag in, bolt back.
On beep shooters will begin blowing up their balloon, once the balloon pops the shooter will drop down to their rifle and engage their 393yd flapper with 1 round, then engage the 514yd plate with 1 round, then the 294yd MGM popper with 1 round. Then repeat!!
**If the shooter successfully hits their first 393yd plate they will be given 20pts (10pts for all other hits). If they hit it before their opponent they will get and additional 10pts for a total of 30pts for their first successful hit if hit before their opponent.
Stage top finisher was Jason with 80 pts
Stage 2 - Holdovers (2 shooters at a time)
(8) Rounds
Shooters begin prone behind rifle, bolts back.
150yd paper, 307yd skinny sammys , 393yd IPSC flappers, & 514yd 8" plate
10 pts per hit
60 sec prep time
Starting prone with bolt back
On beep shooters will have 90 seconds to engage 150yd paper target, 307yd skinny sammys , 393yd ipsc flappers, & 500yd 8" plate from near to far then repeat. Shooters will advance to next target if they miss shot. Once stage begins shooters may not touch their elevation knobs.
Stage top finisher was Soloman with 60 pts
Stage 3 - Get yo Ammo (2 shooters at a time)
45 seconds
5 rounds
10 points per hit
Starting at ammo line with one round in hand. RIfle prepped with empty mag in bolt back.
On beep shooters will go from ammo line with only one round at a time to rifle and engage the 514yd 8" plate. Repeat until out of time or out of ammo.
Stage top finisher was Soloman with 50 pts
Stage 4 - Long range Shoot-n-Cs (4 shooters at a time)
Targets - 8" shoot-n-Cs @ 514yds
60 seconds
(5) rounds
Starting prone on rifle with mag in and bolt back
On beep shooters will engage their numbered shoot-n-C with (5) rounds. Hits will be scored by scoring rings
Stage top finisher was Henry G with 45 pts.
NORMAL 500m pad
Stage 5 - Mine field barricade (2 shooters at a time)
Targets - (2) 8" plates @ 220yds (white)
90 seconds
(9) rounds
Starting port arms, mag in and bolt back
On beep shooter will shoot 3 shots from each level of the barricade. ** SHOOTER MUST RELOAD A FRESH MAGAZINE AT EACH NEW LEVEL**
**shooters must be mindful of the mine field and will be docked -10pts for any mines that are detonated.
Stage top finisher was Rich C with 60 pts
Stage 6 - Seated/unsupported prone (2 shooters at a time)
Target - (2) 10" plates @ 320yds (orange)
75 seconds
(6) rounds
Starting port arms with mag in and bolt back
On beep shooters will shoot 3 shots from the unsupported prone position and 3 from the seated position.
**traditional NRA positions only - no bags for support or tripods
Stage top finisher was Rich C & Jason each scoring 30 pts
Stage 7 - Tresslers light box
(5) rounds
Time is determined by box
(alpha A, bravo B, charlie C, delta D, Echo E) from 70yds to 320yds. (PINK)
A-70yd paper, B-150yd tiny man, C-smallest 220yd PBR steel, D-smallest 320 PBR steel, E- 320 paper
Starting standing behind rifle with mag in hand bolt back. When light flashes next to target engage that target before the next beep and light comes on, continue until all 5 lights have illuminated.
Stage top finisher was Rich C scoring 30 pts for steel hits.
Stage 8 - Bob the builder stage
Targets - 220yd 8" plate
(8)rounds
100 seconds
Starting port arms
On beep shooter will advance to each prop and engage the 220yd 8" plate with 4shots from each prop.
Surveyors tripod then the saw horse
**No artificial support will be permitted except for 1 bag
Stage top finisher was Rich C & Jason each scoring 80 pts
Stage 9 - Old Skool Man on Man with a twist
3 rounds
10 points per hit
10 bonus points for beating first opponent
SAP T-shirt stage prize for Man on Man winner!
Starting at rear line with rIfle prepped, mag in bolt back on bench.
On beep shooters will go from rear line to their rifles to engage the 8" at 220yds from the bench, then engage the 10" at 320yd, and back to the 8" at 220yd. If shooter misses, shooter is done for the stage and stops accumulating points. Stage is to be shot only using support side.
Stage top finisher was Solomon winning the the short action precision T shirt
2nd place Jason 350
4. Aaron 344
5. Esteban 243
7. Larry 198
8. Ben 194
9. Jeff Holder 169
10. Jennifer 154
11. Jeff Hall 149
12. Netza 120
13. Eddy 97
14. Julian 89
15. Danny 186. DNF
16. Howard DNF
Cof was as follows
LONG RANGE TOP PAD
75 seconds
(6) rounds
(8) Rounds
10 pts per hit
60 sec prep time
45 seconds
5 rounds
10 points per hit
60 seconds
(5) rounds
NORMAL 500m pad
90 seconds
(9) rounds
75 seconds
(6) rounds
(5) rounds
(8)rounds
100 seconds
Starting port arms
3 rounds
10 points per hit
				bcrich
- Teaches Shooting
Re: Aug 17 PBR AAR WEGC
Jennifer & Larry blowing up their ballon before dropping to their rifles
Soloman,Jeff Hall & Howard on the line
Rich C on the minefield barricade stage carefull not to detonate any clay minefields with his ejected brass or a mag
Julian from the seated position
Eddy at the Tressler light awaiting his next target command
Top finishers for today
Soloman, Jason,Rich C , Henry G with 2 medals top 308 & top long shot
Group photo of today's shooters
				thegiff
- Real Name: JackBlack
Great aar Rich! So twice I didn't load up the right number of cartridges. Talk about brain fade... click! Gaa I'm out. Need 5 rounds, load 4. Supposed to have 8 rounds and loaded 6 for some reason. Anyway congrats to the guys who medaled, well deserved. I liked the minefield stage. I put my hat and shemaug on it and saw my shells miss them and smack the clays anyway. Lucky none broke.
				bcrich
- Teaches Shooting
Yeah we all do that from time to time.... Brain fart.... Sometimes we load the wrong ammo in our guns , I remember putting a 243 in my 308 at a Vegas match like today's get yo ammo stage. Somebody left a 243 by my 308 pile & o grabbed it thinking it was my round haa!
Jennifer can relate to us now right Jennifer ;)?
Jennifer going against Larry on the man vs (wo)man week side
Netza vs Eddy week side
Jeff Hall at the Tressler light box.
Danny & Esteban shooting seated & unsupported prone
						- Point of Impact
- Real Name: Ben
Great match as always. Thanks Rich and James for giving up your Sunday to run this thing and not fire a single round.   Thanks to SAP for providing the much needed hydration.  Today was one of "those days" for me but had a great time nonetheless.  Congrats to the medalists!
						- Tackman11
- Real Name: Danny N.
Thanks for putting up a great match. Too bad I had to taken off early. Congrats to the winers
				Downrange67
- Real Name: Henry Garay
Rich G., James, & Rich C.:
Thank you for always testing us each month with new and creative stages!
Tomorrow's Battle Is Won During Today's Practice!
				postal
- Real Name: Julian
Knowing Danny..... that wasnt a typo!!!!!!!!!!!Tackman11 wrote: Congrats to the winers
 Bummer you had to leave early- you were doing really well today.
Great job guys.... Match went smooth, Henry G did really great!
I dunno what happened to me... I've been having extraction issues.... but I couldnt hit ANYTHING today.... Not one stage I did well in.....
Ah well..... Sierra Hotel.....
Thanks all for putting on the match, and SAP for the water and T-Shirt.
Hopefully Aaron and I wont arrive late again..... Aaron?.........
				postal
- Real Name: Julian
Thanks for coming out guys and good job to everyone.
We're constantly trying to keep things interesting by coming up with new creative stages. Some end up being awesome and others not so much but i think it helps to break things up either way and keep everyone on their toes.
We already have a couple brand new stage ideas for next month after sitting down for lunch after the match!!
				Treadstone
- Real Name: Jeff
This was the first time at WEGC for Jennifer and I, we had a fun day!  Really liked the random light stage and the minefield.
See everyone next Sunday.
				robojet
- Real Name: Jennifer
Aug 17 PBR AAR WEGC
It's nice to know there's someone to share these things publicly... thanks Rich... I may have forgotten!bcrich wrote:Yeah we all do that from time to time.... Brain fart.... Sometimes we load the wrong ammo in our guns , I remember putting a 243 in my 308 at a Vegas match like today's get yo ammo stage. Somebody left a 243 by my 308 pile & o grabbed it thinking it was my round haa!
 What was funny is Jeff being up next, still not knowing why the rounds wouldn't chamber... and Jeff ripping apart his pack looking for his magazine... that was in my pocket...
We will be marking our magazines now.
Had a really great time - Thanks for putting on a great match!
				Mudlol
- Real Name: Larry
Thanks for putting on another good match. I really enjoyed the mine field stage and the 500 yard pad.
Larry
						Larry
				johnlee
- Real Name: John Lee
Great pics.
						- MichaelV
- Real Name: Michael Victor
Good shooting Gents! And Ladies!
Hope I can make the next one.
Upgrade your AICS: http://www.victorcompanyusa.com" onclick="window.open(this.href);return false;
